I'm not changing case just for looks![]()
Then change it for better cooling performance because your case is WAY undersized for the GPU's you have.
New case and use some silverstone air penetrator fans for front intake.
No vid mate, im just familiair with air penetrator fans. Ive used them in a few builds. 120/140mm. Good static pressure for big heatsinks, and i think theyd work well on rads too. Not a watercooler myself but open to using it sometime.You must've seen the video
Impressive fans, though they don't seem to do well mounted to anything, put a bit of distance between it and whatever its cooling and they work great!
Ive heard of watercooling users using shrouds, sadly cant go that way myself. Watercooling my current kit would cost way too much.They would work well with radiators if the design allowed for better static pressure closer to the fan. A 25mm shroud fixes the issue. Phobya have some lovely clear plexi ones which you can insert lights to.
You just can't see it on the pictures because I haven't taken any pictures directly from the rear. Then you could see that the the bottom fan and HD case fan are free of cables in the airflow direction. You can't do clean cable management in case from 2007 with 0 cut out or no extened room behind the atx panel. Only one way to place SIX SEPERATE PCIE cables and that's to curl them around at the bottomThat bottom fan is pushing throw a bundle of cables
I told him not to throw any more money at that case, those fans and plastic paint would have cost £30+?
I would think of the harder life the GPU's are having
Too much going on in that case.
BIGGER! case needed.
them 3 cards need more air than some extra tacked on fans can provide
like others have suggested its time for a new case man.
^^ I for one do not think anyone here is trying to boot your balls for sake of it.
You come in a public forum with photos of a mess of a set up for some great high end hardware, mainly the expansive 3 GPU's.
Do you expect peeps not post their opinions to try and help your hardware and you?
I will not bother you again IMO but you need a new case simple as that sorry if this input is not what you wanted when you made this thread.
what I want to know is if a high cfm airflow fan or a high static pressure fan under these circumstances will provide the better cooling solution for the cards ??![]()
it wont make any difference for you
Doesn't matter, it looks to be 80/92mm so will most likely have better static pressure than a 120mm fan.
I don't get why so many people are moaning about his setup, his temps are good so why keep tell him to waste money on a new case he doesn't need or want? O.o
