Blanket statements Roff ^^^^
Whats that supposed to mean? anyhow the facts are blatantly obvious and reproduceable for anyone with a recent i7 and a 780 let alone 780ti - something IS wrong with their numbers.
@Matt.. just for comparison i got 71fps on Ultra 4xMSAA @ 1080p on my system standing in the same spot u guys do on Siege. Just didnt know how to screenshot it or more likely just cudnt be arsed![]()
Inconsistencies of multi player benchmarking. That's why its wrong to call results false in this instance. Or say but i get 5 times that much fps with my gpu in 2d mode etc. As it was all benched on the same system/server you can be sure its correct.
As for taking a screenshot, bring up the console and type screenshot.render and hit enter. The screenshot will be in your documents folder. I will try a different server and see what i get again at 1080P DX on Siege.
Sorry humbug but its of no use to me using that.. My Metro video was done with OBS and Quick Sync and the hit is minimal. Probably less than 5% as its using the IGP on my 2700K
Heres another video on Paracel Storm with Vsync disabled this time.
Same settings as before..
Apologies for the poor brightness quality. Will have to sort that out if i do another video.
Oh.. Max VRAM was 2.6GB for this one.
I get a noticeable performance hit with Mantle when i go into borderless mode. Its a shame as its stopping me from recording footage. However Dice have crossfire working in Mantle at least in Windowed/Borderless mode somehow.
It does for some reason, yeah.
Can't wait for RadeonPro 2.0 https://twitter.com/radeonpro
shouldn't need boarderless.
Sweet. Surely we won't be able to record Mantle though until the SDK becomes available?
I'm sure AMD are seeing to it that Mantle will work in RP.
Do you know that or just a hunch? Cos that sure would be an awesome feature. Maybe i should give Sam a nudge.![]()
Oh you female doghow jealous am i now?
Be sure to give us a run-down on it.
Go ahead. reproduce it, if only you knew what they did and where in the game. right?
You guys need to understand the inconsistencies of multi player benchmarking.
Not saying that the 780(ti) v 290(x) performance would be any different but the point is as I said - using the settings they claim to be using you simply can't find a scenario under normal circumstances that you can get result that low below the normal for a 780 let alone 780ti on that map - no matter how hard to try - the busiest 64 player server with most of the action crammed into where your benchmarking from the worst possible bits of the map etc. you will still see results comfortably above what they have.
Its literally impossible when everything is work as it should be to see those kind of numbers from a 780(ti) with those settings on that map under any normal benchmarking circumstances (and likewise the 290 results are probably low for what they should be but I can't answer for that as I don't have one to hand to test on the map).
