Thinking about upgrade (£400)
28 Jan 2008
Manchester
I built my PC about 5 years ago and since then I only upgraded to 560ti. I don't game as much as I used to back then and to be honest it can still play most of my games at medium to high settings. I use my PC from time to time to work from home, doing CAD, mostly construction drawings but some 3d modelling as well.
Ideally I want to make it faster but also quitter so I'm after graphics card that can beat my ASUS GTX 560 Ti DirectCU II. I want to get SSD and ideally that means new motherboard with SATA-III. Would you recommend upgrading my CPU at the same time? At the moment it's running at stock but I had it stable @3.8ghz so I could always overclock it again.
Budget up to £400 for GFX, mobo, ssd and perhaps CPU. I have no preference over Intel/ AMD or Nvidia/AMD. I have Corsair H50 so I shouldn't need a cooler?
So OcUK what can give me best increase in performance?
Thanks
This is a good lot, should be able to sell current stuff for a bit to cover it.
Does your old board use DDR2? If so you'll need to buy new memory also.
EDIT: No, don't worry saw it doesn't.
