New Build Help
Caporegime
4 Jan 2011
As per the title need help getting a new build from scratch bar peripherals, so the box and monitor basically.
Budget is £1600-1800
Looking for a 27" monitor and probably not wanting to spend more than £400 of the budget on it. Open to suggestions on spending more or less on it.
If it were my money I would lean towards Fulax's build but swap the 290 to MSI gaming edition as it is slightly better reviewed over the Asus (and still fits colour scheme).
I can personally vouch for the Iiyama screen it is great for the money.
The Corsair cube case is a beast
240mm liquid cooler will be cool and quiet
Cheers guys and yes Stulid it is for gaming, I'll go through the builds later with my friend, I see you've recommended the monitor I currently have so will probably push him towards that, didn't realise it had come down £150.
Stulid any idea what ocuk would charge on top for this to be pre built/OC'd+shipped?
Best to ask in Customer Service.
YOUR BASKET
1 x Gigabyte GeForce GTX 780 WindForce 3x OC Rev2.0 3072MB GDDR5 PCI-Express Graphics Card (GV-N780OC-3GD) £395.99
1 x Asus VG278HE 27" TRUE 144Hz 3D Widescreen LED Monitor - Black £359.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £239.99
1 x Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard £152.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £129.95
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £119.99
1 x Silverstone Strider Gold Series - 850 Watt (SST-ST85F-GS) £99.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £65.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
1 x Alpenföhn K2 Mount Doom CPU Cooler £49.99
1 x Samsung SE-S208DB/TSBS External Slimline 8x DVD-RW (TV Connect) - Black £21.98
1 x NZXT CB-LED20-WT 24x White LED Sleeve - 2m £13.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - White £8.99
1 x BitFenix Alchemy Molex to 4 x SATA power extension - White £6.98
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - White £5.99 (£11.98)
2 x BitFenix Alchemy 6+2-Pin PCIe Extension 45cm - sleeved white/black £5.99 (£11.98)
1 x BitFenix Alchemy 8pin EPS extension 45cm - White £5.99
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - White £4.49
4 x BitFenix Alchemy 2pin I/O extension 30cm - White £3.95 (£15.80)
Total : £1,797.10 (includes shipping : £20.10).
