Also if i overclock my Pi which i certainly think it needs do i really need a Heatsink? or can i get away without?
Keeps my heavy overclock at around 40C, silent and rock solid.
It's probably a good idea to prolong the life of the Pi.
I decided to op for a cheaper solution and simply connected a 110mm fan to the 5v I/O pins and plonked it ontop of my PiKeeps my heavy overclock at around 40C, silent and rock solid.
Whats more important for a good stable overclock is a beefy 5v supply, I tried various 1.5A phone chargers and none could keep it stable @ 1.1Ghz.
I connect it too the 5v output of an old ATX power supply and this stabilized the overclock so I knew it was a supply issue.
I have since bought an Anker 5A phone charger and this now keeps my poer hungry setup rock solid![]()
Can you guide me to the fan you used and any installation guide you may have followed, i may just go for the heat sinks as it seems easy to do. Does it get really hot when overclocking then and how do you find the temperature out and the speed of the overclock is there a programme to see if its stable? also is it safe to be left on at all times when overclocked?
sorry for the questions.
Thanks.
How come mate and I would much rather wireless than mess with a ethernet.. I've heard mixed reviews with the edimax wireless dongle hopefully it will work fine as we have a great connection.
but streaming high bitrate 1080p VC1 Blu-Ray ripps is not gonna happen over WiFi!I just used an old fan from my fan box (I always cannibalize faulty products before chucking them out)
Any fan will do, -/ground = i/o pin 6 and +5v = i/o pin2 on the raspberry pin header.
raspBMC gui has readouts for both CPU & GPU temps
As for buffering issue I cannot really help, my Raspbmc doesn't suffer any stutter even on streamed 40GB VC1 BluRay .MKVs, silky smooth
Streaming 720 even 1080p HD using WiFi will work fine for OnDemand stuff as they have naff low bitratesbut streaming high bitrate 1080p VC1 Blu-Ray ripps is not gonna happen over WiFi!
Final question and this has been baking my head all night. How do I fix the youtube plug in I'm no pro with ssh or Linux but I eventually figured how to edit the youtubelogin.Py file and replace a paragraph of text as required and tried to save it but it said read only I then try to figure how to make it read, write so I mounted storage and made it read write (I think) by putting in the ssh "mount /storage -o remount,rw" then nano youtube login.py and tried to edit the text from there and it saved the file but still no look. Not even sure that's the right way to do it either so any confirmation and instructions would be grand.
I've seen people say put your pis openelec in the Windows browser and you can access files however when I do this it just brings up xbmc and then my movies tv shows and music nothing regarding the files in my pi? So basically is there a way to edit files and add install files on to my pi remotely without ssh? So I know where I am and what's what in a windows format
also if i wanted to install a deb file or a addon that i cant get on XBMC where do i put it in the root directory?
