Haswell-E, X99 & DDR4 in June ?
i payed £190 for 6gb (3x2gb) of 1600mhz Corsair tri channel early in 2010 :(
Meh, you young whippersnappers don't know how good you've got it! When I built my first PC, it cost me £30 (around £43 in today's money) per MB! :eek:
I could only afford 4MB :(
EDO RAM :D. Found a stick of that not so long ago, absolutely brimmingly compact. Think it was 64MB, dread to think how much it was worth at the time. I was running 8MB lol.
That was it! You've got a better memory than me, couldn't remember what it was called for the life of me!
Great, here's waiting for another Intel CPU with a 5% performance improvement, pointless DDR4, a new platform they will offer little in the way of new technologies and innovation, reduced overclocking potential and a sky high premiums. :o
Err, this is the biggest leap forward in Intel CPU performance since the first generation bloomsfield I7's were released.
8 cores
Much larger L3 cache
DDR4 (corsair, gskill etc will release 3000Mhz kits early on most likely)
Quad channel memory, ddr4 etc.
As multi threaded games, applications are becoming much more common place, the 6 and 8 core versions, armed with all that L3 cache, will be a lot more than 5% over the current generation.
It will be an increase in max FPS for benchers etc and people running 3+ card setups.
But it won't be necessary in any way for anyone as games are 99% bottlenecked by GPU.
Of course there's the occasional 240hz gamers that can actually max out a CPU like that.
Don't be surprised if Haswell E turns out to be very poor for the above and it is better to stay on X79.
If the mainstream Haswell form book is anything to go by an eight core CPU could be total rubbish for overclocking and may struggle to reach 4.2 or 4.3ghz. This is fine for zeon CPUs but totally useless for benching or 3/4 card setups.
There is that, yes. most if not all Ivy-e chips on here struggle to beat majority of 3930 scores. But one doesn't need raw clock speed when coupled with 8 logical processor cores. 20k Physics at 4.5? ;)
Time will tell. Still don't think it'll be June though lol.
Don't buy one then!!!
Next...............
June no and no!!!
Next...............
June no and no!!!
I won't. Unless your aging X58 system is on it's last legs and being held together with gaffer tape anyone with a Sandy-e or Ivy-E will have no compelling reason to upgrade.
8 cores
Those are just technologies it supports not reasons to buy. What am I going to with expensive DDR4 that I can't do with DDR3?
I've been waiting for this to happen since 2006, until Intel starts selling affordable 6 core parts most developers aren't going to bother coding games to take advantage. Were a long way off, Intel don't even have a budget quad core anywhere in their lineup and I would gobsmacked if Haswell changed that.
A faster system to bench on :D. Enthusiast > mainstream
Pc's don't drive game development - consoles do. Now the Ps4 and xbox 1 8-core consoles are out we'll see more developers utilising 'mowar cores' ;) ;)
Whilst intel has always had the upper hand in the IPC race, AMD have the mowar core race sorted - especially now that their chips are in both consoles.
won't be long till you don't need a super expensive 8 core chip but a much cheaper AMD one will do the job just as good for games. Let Intel keep trying to milk us - all their doing is restricting themselves to a smaller percentage of a shrinking market (no wonder their already announcing losses lol!)
I guess your either ignorant or you've been living under a rock for the last few years. There are plenty of well multi-threaded applications/games, BF4 is just one example. If you would like further examples (instead of using google/review benchmarks) then let me know.
It seems you're also ignorant as to the benefits of DDR4. I'll list them below for you, as you don't seem to be able to use google yourself. Also note that years ago we were all using DDR1, then DDR2 etc. This is just another milestone where newer, faster memory will be introduced.
Benefits of DDR4:
16GB dimms. So much greater capacity - plus *may* increase overclocking potential, as we've seen in the past that using less memory dimms can improve your overclock
Lower power comsumption, always a plus
Faster speed! Although the stock speed will be only 2133 - remember we'll soon see much faster models than the standard spec modules. DDR3 started at 800mhz I believe, and we're now upto over 2000mhz!
Of course, if you don't feel the need to upgrade, then don't bother, just don't whine about how 'worthless' this new platform will be. Buy it, or don't.
Benefits of DDR4:
Well said mate. Personally, this is the most excited I have been about hardware since I built my X48 Rampage, Q6600, Xfire 4870 system
