Is there any truth that AMD cards are bad at Tessellation
Man of Honour
21 May 2012
Dalek flagship
Well lets find out
What would be helpful is if some people can run the Heaven 4 bench with everything maxed except the tessellation which should be set to off. If anyone has a GTX 780, GTX 780ti or Titan and can do this, when i get home from work in the morning I will do the same with my 290X.
In theory if the AMD cards are bad at tessellation, by turning it off in the heaven 4 bench then my 290X should be able to close the gap.
If anyone is up for it I think this will be an interesting exercise and may answer a few questions.
Well lets find out
No there isn't, there is however Nvidia and there general shady stupidity of ruining everything for the sake of winning.
Tessellation is predictable and provable. Grab a piece of paper, draw a big triangle, split it into two more, keep doing this. You see how eventually you get to a point that you can't actually see new triangles? What happens is, there absolutely, categorically IS a limit beyond which tessellation is absolutely worthless. So sensible hardware makers design a tessellation unit to work effectively at this level and waste no hardware on levels you can't ever see......
Then you have Nvidia, why not over engineer the tessellator, then pay a few games to use tessellation WAY beyond a level you can physically see... but your hardware will cope great with it and AMD hardware won't.
It's silly games, it's not realistic, you can only induce a massive performance delta between AMD/Nvidia via tessellation at a level you can see zero effect from.
Benchmarking is pointless, enable the tessellation limit in control panel and AMD drivers should limit the excess and useless tessellation from being done, I don't know if it would effect benchmark results. But it's now Nvidia are getting such good tessellation results. Personally I don't care how fast my card can tessellate beyond a level of detail no screen made today can actually show.
This is exactly no different to what Nvidia did with Crysis 2(I forget which one it was to be honest, 2 or 3 I think anyway). Massively massively over tessellate a completely flat object to make something that topples AMD hardware, doesn't topple the Nvidia tessellator, but offered precisely zero IQ improvement. We're talking about Nvidia pushing tessellation up to sub pixel changes that can't possibly be seen... the fact that Nvidia is wasting transistors to do this faster just to be able to mess around in benchmarks is a joke.
There is a crap way to do tessellation, a smart way, and a completely mental only out to cheat in benchmarks way... guess which way Nvidia went.
I am not sure that AMD cards are as bad at Tessellation as some people say, I find my 290Xs seem to do quite well with Tessellation from the limited amount i have seen. This is the reason for doing the above exercise to see if it is the Tessellation in Heaven holding the cards back or it is something else.
13.11 sig rig all stock, xfire disabled, settings as advised
Great post. I remember that crytek for ryse son of rome they reduce the triangles from 150k to 85k because the iq was the same. And they gained better shading + no LODs.Triangles have a diminishing return when you go over 50k. Its not like 15 years ago that double triangles (60 triangles to 120) resulted a way better mesh.
I don't have a 290X but i'm still up for it, for whatever its worth.
From the Heaven 4 thread: Score 796, GPU 7870XT @1215/1600
Without Tessellation: 1200 / 1600 Score = 1061 (+33%)
I would be interested to see what level of performance gain a GTX 660TI has from turning off Tessellation.
GTX780 (not at stock). Pretty sure I can get that upto atleast 90 as I wasn't quite at max clocks - 1250ish on the core.
*THAT image*
That image has been debunked, if your starting mesh was designed with 60 triangles in mind then 60,000 means you start over and not try and gild a turd. I think Nvidia do have a leg to stand on as far as pushing boundaries but not with tesselated water hidden under the map out of sight.
I just add the graph to see the difference between 6k triangles and 60k.Nothing else. Even if you make a mesh with 60k triangles going to 120k will increase by 5-10% the IQ.No more.But going from 60K to 120K is a huge amount of power
Also if you have experience with cry engine when you start a level its only water terrain. Thats why it seems that the water is over tesselated when its not. Its just the base terrain of cry engine
I'll do this. :)
Wouldn't it make sense to do a bench without tessellation then one with? And work out the percentage it impacts the card having it turned on?
Pretty much or else you might as well not bother lol. Unigine will still favour NV cards. Valley for instance.
http://www.ozone3d.net/benchmarks/tessmark/
Unfortunately tessmark is OpenGL, something else AMD cards are unbalanced in due to NVs own extensions. Can't win lol.
Stock 290X @1000/1250
4930k @4.7
With extreme tessellation
With tessellation disabled
Increase in FPS 35.45%
I will be back in a bit after I have tried the same on a single Titan.
