- 21 Jul 2005
- Officially least sunny location -Ronskistats
Get another 7970?
Dammit Mantle is working on my 7970s now. it's not a thing green line like you guys but with 2xAA the memory used never went over 3041mb. And i was getting crazy high fps. What to do? i've got 2 tri-xs here one of which i can't use as it literally won't fit in my GENE V. Send back the Sapphires or buy a new motherboard and or cpu to use the sapphires (which is super mega overkill for 1080 even at 120hz...)
Yeah. I'm thinking of getting a 4770k as my 2700k is average at best. That way I'll get the PCIe 3 lanes as well
Oh I've already got 2 7970s. I need to get on MM and sell them or I'm going to end up like Kaapsted.
mantle Performance on properly the most demanding Battlefield 4 map
Didn't drop below 100fps Wow! run that on DirectX and frame rate wouldn't be anywhere as good.
Different gravy.
Can't wait to get my hands on your motherboard and try out x16 x16 xdma crossfire.
I also might have to use your recording methods.![]()
Yeah its stunning, Mantle is So DAM good. You in for a treat this MB is something. Gives you the most flexible GPU configs possible.
I'll be using the 2x16 slots though. Just testing on this board that's going back the space between the x16 slots is twice that of my p8p67 deluxe and that had a decent space between the gpu's.
So out of 100% that have tried Mantle 80% love it while the other 20% suffer from PEBAC.![]()
Problem exits between Arkham City?![]()
