H100i Fans?
22 Oct 2012
The Moon
Hi, I am wondering if this setup will be good, or if i should buy some other fans.
Thinking of running h100i in a push pull setup on a air 540. How about using af120 at the top, and the stock fans at the bottom?
Or should i just buy another set of sp120s?
AF fans aren't designed for restrictive applications like radiators. SP fans are.
But then again, there's no point in push/pull on a H100i. One set of fans is perfectly adequate. Adding more fans makes little/no difference in temps.
