Caporegime
- 13 May 2003
- Warwickshire
Hi all
I'm doing a small tiling job in our downstairs toilet to replace the old black ones that were there before. I've got some 8mm tile trim, but my question is about where the tile trim should ideally go and how I should fit it.
Here's the tiling area:
I was thinking about laying the trim as per the red line in the photo above, with the black lines showing joins. The flat part of the trim would be adhered to the vertical wall as opposed to the window sill...whaddya reckon? And should I add trim to the bottom horizontal underneath the sink?
I've done some tiling before but didn't do a brilliant job of the trim part and am not sure what the accepted practice is for when tiles finish in the middle of a wall.
Another question: is there some trick to the 45 degree join where vertical trim meets horizontal? Or is it just a case of cutting it with a sharp Stanley knife blade?
Many thanks
Many thanks
