- 22 Jul 2012
- London
Two slot gap and a two slot card = One 290
Two slot gap and a two slot card = One 290![]()
More room than that believe it or not. Maybe 1/4th of a 290.![]()
I think that's because most of his subscriber base are moronic
Not really watched any of his latest videos.
He's not too smart himself.
That's why i've not watched many of his videos lol, he's a bit of a plonker, but can be funny (sometimes)
Bit of an odd one tbh.
Seems like it's making an example for the sake of making an example.
OT: Is mantle now working properly with 7xxx Xfire? I haven't been keeping up (or plaing BF4 either tbh).
I believe the 7000 series Mantle tweaks are coming April.Wow, this thread has had some cleaning up
Anyways, is the memory bug sorted for Mantle in this yet or is it still using a chunk more?
Its not a bug, its something to do with the way Mantle manages Memory, it preloads a lot of textures so it tends to use more.
This means 2GB cards have a hard time with it.
AMD have said there will be optimisations specifically for 2GB in April.
Never the less, after a lot of messing about i found i'm still able to run very high settings in BF4, i wouldn't play higher settings than i do as my GPU would not run the high FPS i like, so its a bit meh.... anyway.![]()
Fair play but I still don't get why you run Mantle when you had perfectly playable frame rates with ultra settings on 13.12 drivers?
You are lowering the IQ to get more fps but isn't that counter productive?
In DX my FPS often sink to 50, even as low as 40+, in Mantle they constantly stay at 80 or more, i have actually locked frame rates to 90 and that's pretty much where they stay, almost no variance in FPS. its glorious.![]()
Must be nice to have 90fps on a 120hz monitor! unless you have a 60hz monitor then you have to ask yourself, 'whats the point?'
