- 2 Jan 2012
- UK.
*Update September 2015*
You can pick a compatible 2TB external drive from a few places now. Or buy a HDD only 'Samsung M9T 2TB' which is a bit more expensive than buying an external HDD and removing the HDD yourself.
I won't mention best places to buy here as not sure if it would breach the rules. Please be aware if you do choose to buy an external HDD and remove the portable housing the warranty is gone as far as the external product is concerned. I'm not sure if Seagate etc would honor on RMA on the drive itself if needed. Maybe someone has more insight on this. Tbh you would have to have hands like King Kong to do any damage to the drive itself by opening the housing..
The one I am using is the 2TB Seagate Backup Plus Portable Drive. It's 2.5" and comes in a case with a black bottom and silver top (others colors are available albeit more expensive). Inside this portable drive you will find the 2TB Samsung Spinpoint M9T.
So let's get started.
First thing is to backup yours and other users save games etc. Do this by logging into each profile going to storage management and backing up the saves to your USB stick. Also sync your PSN trophies.
You will need the PS4 software, latest version atm is System Software Update 2.57. You can download this here - http://uk.playstation.com/ps4initialise/
(You need the full 800mb+ file)
Now you have backed up your saves, PSN trophies synced, and OS software downloaded and placed on USB, it's time to get to the hard drive..
This is what the box looks like
The external drive housing.
To take this thing apart, get a small think piece of plastic, like a guitar plectrum etc. Gently separate the top lid from the bottom. Working around the edges.
Till it starts to look like this.
When you get the lid of you will have this.
The drive can just be gently pulled out from the bottom of the case, it is not fixed in anyway to the black bottom part.
When fully removed the drive has foil around the egde, just peel this off it comes of easy. The sata to USB adaptor can be gently pulled off from the end.
Now you have just the hard drive itself, you need to remove the HDD installed in your PS4, the black shiny housing part on the PS4 will clip apart from the main case. Revealing the HDD slot. One top screw will allow the drive caddy to be pulled out. The drive itself is held in the caddy tray by 4 screws. Unscrew these and remove the old drive (In my case SSD) and in with the new drive. Screw it back together and slide the caddy tray back into the PS4. Put back the one top screw and fix the top panel back into place.
With your USB stick in the PS4. Turn on the system. You will get an error and be asked to attach your PS4 control cable and press the PS button. Now follow the instructions to install the PS4 OS. You will come back to the start screen to enter all your preferences. Region, Language etc. Click on your profile and sign into PSN to get your profile back. From here enjoy a much larger hard drive and get your games etc installed again
