**Official THIEF-Incorporating AMD™ Mantle™/True Audio™/Bench mark Thread**
Status
Not open for further replies.
Cheers Mart and nice boost to the minimums for sure :)
Definitely an improvement, I'll have to give it a bash with it not being locked to 60 FPS (That'll be down to the UE3 engine, I assume changing an .ini as per)
But looking back at UE3 games, mins as low as 40 surprise me really.
It isn't fps locked for me and in game, I sit anywhere from 110 to 240 fps
God knows then, the benchmark certainly hits harder than the real game (Which tbh makes the benchmark somewhat pointless, as it's not relevant to the gameplay)
But my FPS was practically pinned at 59.9/60 the entire run through.
Pretty sure it was FPS locked for me then too.
An in game shot with full details for me.
Make sure you have Vsync turned off if you are being capped at 60fps, I had the same issue till I realised it was enabled.
Wow! TrueAudio is stunning :D the difference it makes to the surrounding environment. Only onto the second level and so far really liking it. Started on Master setting.
What I have noticed is the game don't seem to be using second card? Hwinfo reports no usage.
Its using the sound card thats in your R9 290 ;)
I also see gains across the board with Mantle over Direct X (Again, I still think the benchmark is largely irrelevant to gameplay)
This is my R9 290 - 50mv @ 1050MHZ/1200MHZ (Pretty quiet)
I've taken pictures on my phone so you can/can't see the OSD and also I screenshots don't always work :p
Here's the DirectX 11. Could have swore I got higher mins before I updated the driver......................... *Tin foil hat*) ;
Here's Mantle
Higher FPS across the board (Derp)
What about 3D martini?
It's greyed out for me.
Greyed out, I also can't see a none TA option.
Status
