- 21 Jul 2005
- Officially least sunny location -Ronskistats
What voltages are you pushing for these clocks guys?
I also think that my turbo mode is set to auto, not sure what difference that makes though
Will be performing a series of Power consumption comparisons between overclocks. I think this power hungry fx stuff is over played. Sure compared to other CPU's its power hungry but unless you are rendering or folding all the time, it makes less of a difference than you think. Cheap boards not designed for (which also pre-date) 8 core fx chips fail ad throttle due to the power draw but imo this is mainly the fault of the motherboard and the buyer matching the wrong components up rather than the CPU.
Will do one at varying clocks and voltage, varying loads which compare stress tests to real life game loads and finally temperature vs power consumption. Much lower temperatures from watercooling or high end air cooling will lower the resistances a fair bit when comparing to stock coolers, maybe we will see a half decent drop?
Hopefully i will get this finished and polished up by next week.
I know that this is an overclocking thread but I think I will get the best answers here.
My current setup is:
CPU: AMD 1090t 3.5Ghz
RAM: 8GB DDR2 900mhz
GPU: GTX 680 - +160 Core, +460 Memory
I play a lot of BF4 and some times FPS drops below 30fps and most of my settings are on Medium. I have done a lot of research and feel that it could be a RAM issue.
So I have been thinking about upgrading. Getting a CrossHair V Mobo, some 1600mhz RAM and an AMDfx 8320.
Do you think I will see much improvement?
Also, with all the new components going in, I may need to re-install Windows.
I'm currently using Win7 but I did read that going to Win8.1 could yield some more performance improvements on an AMD-FX CPU because it introduced some new instruction sets.
Any info on this would be appreciated.
