What lead are you going to use to connect your cards.
DP Kaap. HDMI is only 30Hz.
Samsung U28D590
Not enough VRAM on a 290/X for 4K![]()
 if that aint enough your titans will struggle
 Nice screenBut really your titans will be a good match for it imo and you can always add anotherNice screen
Do OCUK sell DP leads with enough bandwidth.
 I will have to look into it8gb 290x mateif that aint enough your titans will struggle
Dunno Kaap. I was hoping it came with oneI will have to look into it
Got the monitor on order as well,will get it next week. And yes it comes with a dp cable included. Will be running it on 2 x r9 290 crossfire water cooled 1250 core 1500 memory. Should be good with that.
Sweet. How come you are getting it so quick?
Dp gives 60htz. Hdmi gives 30htZDoes DP give 60hz?
Does GTX 780Ti have DP?![]()
Does DP give 60hz?
