Live streaming Mantle benchmark@ 1080p
Hope my ping is ok..
Bloody OBS crashed for the first time i've had the damn thing..
OBS has encountered an unhandled exception and has terminated. If you are able to
reproduce this crash, please submit this crash report on the forums at
http://www.obsproject.com/ - include the contents of this crash log and the
minidump .dmp file (if available) as well as your regular OBS log files and
a description of what you were doing at the time of the crash.
This crash appears to have occured in the 'c:\windows\system32\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: 80000003
Fault address: 000007FEFDA53CA2 (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.613b
Windows version: 6.1 (Build 7601) Service Pack 1
CPU: Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz
Yea Matt was using OBS and running BF4 in Borderless Window Mode. Then in OBS just set it to Monitor Capture
I use this same method to record BF4 when running Mantle too.
Lol i wondered what happened.![]()
You dont have to fire up BF4 to change API.
Documents > Battlefield 4 > Settings > PROFSAVE_profile (I open this with Wordpad) then..
GstRender.MantleEnabled 0 = DX
GstRender.MantleEnabled 1 = Mantle
Then just hit Save.
Job done![]()
Out of curiosity as to what would happen I changed this to mantle with my nvidia cards, I was expecting and error code or something but the game just defaults its self back to dx11![]()
Sure
In all honesty I just wanted to see what error it would throw out, bound to be one or two BF4 errors I haven't added to my collection yet.
I have a new suggestion. Make the file read only after you select Mantle and see what happens.![]()
Tried mantle on my nephews system tonight, (i5 3570k at 4.2ghz, amd 290 stock). Yes fps were higher, but it didnt feel any different from my spec in sig. Game was smooth. This graph gets bandied about, and it is faulty tbh.
http://forums.overclockers.co.uk/showpost.php?p=26038566&postcount=7262
The reviewer is running the game with at least 140% res scale to skew the nvidia 780ti results.
Humbug, personally i think mantle is brilliant. We need companys to force things upwards and push the technology, any company that does so has my respect. Amd on the gpu front are doing so with mantle, and their cards are cheaper. But i still gota say mate, in that graph i quoted. The figures for a 780ti are way way too low on those settings. Theyre more akin to the figures i get on a single stock 780 using 150% res scale at 1920x1200 with everything else maxed.
humbug - The DX screenshot is only showing 83% and 36% GPU usage?
 AKA the problemHumbug, personally i think mantle is brilliant. We need companys to force things upwards and push the technology, any company that does so has my respect. Amd on the gpu front are doing so with mantle, and their cards are cheaper. But i still gota say mate, in that graph i quoted. The figures for a 780ti are way way too low on those settings. Theyre more akin to the figures i get on a single stock 780 using 150% res scale at 1920x1200 with everything else maxed.
