Well i'm only 8fps off Matts single 290 score so not too bad of a result![]()
I think you can do better with some tweaking. Get your cpu clocked up to 4.8ghz and experiment with your clocks. I think there is perhaps more to be gained from your setup. Maybe try moving the memory up in 50-100mhz tweaks until you find that point at which performance drops.
