- 14 Feb 2011
Ya, had to double check.
Nice going Geeman... Holding up Team Green nicely![]()
Not bad for stock Air cooled.
Yep and I need to grow a pair, as I am a big bottleboy with benching now![]()
Overclock that CPU and give it some on the Titans.![]()
You'll have plenty more in the tank.
Had the CPU at 5Ghz (I think for this or was it Bioshock).
There is... Maybe I will have a play tomorrow![]()
Can someone with a slower GPU than mine put up a score? Thanks![]()
Yes i might do a HD7770 run soon.![]()
I'll raise ya! 7850
ta...Yes i might do a HD7770 run soon.![]()
