MSI Afterburner 3.0.0 Beta 19(2014-3-27)
Caporegime
12 Jul 2007
United Kingdom
Changes
Added optional unified GPU usage monitoring path via D3DKMT performance counters. You may tick “Enable unified GPU usage monitoring” option in “AMD compatibilities properties” in “General” tab as a workaround to replace native AMD GPU usage monitoring if it is working improperly (e.g. broken GPU usage monitoring in AMD ADL API for AMD Sea Islands GPU family)
• Added basic monitoring for unsupported GPUs (e.g. Intel integrated iGPUs):
o Now GPU usage and videomemory usage can be monitored and displayed in On-Screen Display on any GPU, so you can use MSI Afterburner to monitor graphics subsystem on laptops without dedicated NVIDIA/AMD GPU
o Extended GPU usage monitoring for Intel integrated iGPUs. You can independently monitor usage of main GPU execution unit (labeled as “GPU usage”) and MFX unit (labeled as "VID usage" to keep NVIDIA-styled GPU domains naming)
• Added “NV12 compression” to the list of available video formats to “Videocapture” tab. This format can be used to replace uncompressed video recording with fixed 2x compression ratio at the cost of some color information loss caused by RGB to YUV 4:2:0 color space conversion
• RivaTuner Statistics Server has been upgraded to version 6.1.0
Download Link
http://download.msi.com/uti_exe/vga/MSIAfterburnerSetup300Beta19.zip
Source
http://forums.guru3d.com/showthread.php?t=387818
Hawaii users the negative voltage setting bug is now fixed in afterburner. You can now set any negative voltage offset you desire. I also recommend everyone tick enable unified gpu usage monitoring.
You get much more accurate and consistent gpu usage monitoring, unlike previous where it could fluctuate a fair bit.
Scotty also has a habit of doing these afterburner threads as well, so add him to the fired list. Theres a new playa in town. :cool:
