Is 75% the go to LLC option then?
After doing a bit more digging (it's a slow day in the office! haha) I've come across the mention of the HPET which can be enable/disabled in the BIOS with varying results of improvement. I'll be trying this when I get home later tonight but in the meantime has anyone had any experience with this? From the manual it lives under the south-bridge configuration of my mobo
Following up with my little adventure disabling the HPET or enabling it completely including in Windows does nothing. I'm already set at 100 on the PCIE frequency so am pretty sure it's game related. Maybe if I didn't even have that little graph running I wouldn't notice it as much but now I know its there I just can't leave it alone!![]()
fingers crossed for the patch they've admitted to delaying naval strike forOk after following the asus guide i came accross a couple of things i hadnt done. i upped the voltages on the vdda, nb, and ram to the low end of their advised specs. I then enabled hpc and set cpu llc to ultra high, nb llc to high and cpu, cpu nb and dram currents to 130%.
I now have it running @4.83ghz - 1.5125v with a 300 x 16.0 multiplyer
I will just do a quick boot to bios to get the ram, nb and ht speeds and voltages and edit this post with the info. I didnt know how to build a pc last August ive come such a long way since then.
Ok here is my settings:
Ram-1999mhz @1.57v
NB - 2400mhz
Ht - 2400mhz
Cpu/nb - 1.25v
Cpu vdda - 2.55v
Nb - auto
Nb ht - 1.25v
Nb 1.8v - auto
Sb - auto
Then all the following are disabled:
Cool n quiet, C1E, SVM, Core C6 State and APM Master Mode.
Just HPC is enabled.
Im about to do a prolonged Prime95 blend test to see how it gets on. Id like to hit 5Ghz but it aint happening I dont think.
At the mo I have the cpu and gtx770 being cooled by 2 120mm rads but I'm planning on upgrading to a fractal midi r2 case and swapping the 120's for an 80mm thick 240mm rad and the 47mm thick ek xt240. Plus I plan on using a 150mm res instead of an 80mm.
At the moment playing bf4 on ultra with the cpu clock above and gpu boosting to 1358mhz I'm getting 38 deg c max on the gpu and 57 deg c socket and 49 deg c core temp using hwmonitor. I expect that to be much lower with the new case and rads as my current case has no cable management and there's not much room between components.
