Project: Thurst
Hello Guys,
Welcome to my first ever attempt at making my PC look anything other than a mess. I doing this on a serious budget so bear with me it may take a while
Spec:
CPU: i5 2500K(Currently clocked at 4.6 on air 24/7)
MB: ASROCK Extreme 4gen3
RAM: 16gb 1600mhz Hyper x Genesis
Drives: 2 x 60GB crucial M4 1 x 2TB WD Black
PSU: Thermaltake toughpowerXT 675W
I already own the above and need to hang as long as I can before I upgrade due to funds.
Watercooling kit so far is below:
YOUR BASKET
1 x asus radeon r9 290 "voltage unlocked" 4096mb gddr5 pci-express graphics card £299.99
1 x ek water blocks ek-d5 vario x-top - acetal (incl. pump) £89.99
1 x ek water blocks ek-fc r9-290x - acetal £79.99
1 x ek water blocks ek-supremacy - acetal £49.99
1 x ek water blocks ek-coolstream pe 360 (triple) £49.99
1 x ek water blocks ek-coolstream pe 240 (dual) £39.95
1 x monsoon 13/10mm (id 3/8 od 1/2) free center compression fitting six pack - white £27.95
1 x xspc razor r9 290x / 290 backplate £24.95
total : £672.40 (includes shipping : £8.00).
i have a phobya res already to go with this lot, just need to decide on fittings and tubing? fluid colour will be yellow thats for sure
so the plan is for the time being, well at least until i have sorted the card issue! to run just a cpu loop with the one rad, then later on add a second 240 rad and gpu water block to match the cpu.
all of this is going in here which turned up today:d
Finally all stripped ready for some work to begin.
Hello Guys,
Spec:
YOUR BASKET
hopefully my 240 will be fine.
and measured up round back for the pump and wot not. Got top rad painted and some detailing on the mobo done.
