Can someone with a slower GPU than mine put up a score? Thanks![]()
Downloading it onto my HD 5970 system now, I have no idea how it will run.![]()
I might have a chance![]()
1080p
i7 975 @4.2
Single HD 5970 (2 GPUs) @850/1200
Two HD 5970s (4 GPUs) @850/1200
The bench runs great on these old cards.![]()
2600k @ 4.5ghz,7850 @ 1220/1470
yh,idk??
does cpu have any affect?
Makes you wonder if its been greyed out for anyone else. Its not something you'd likely notice.
mine was the p version also
once you set all your settings set the hardware config file to read only,stops the annoying window from happening instead of full screen
