Dirt Showdown Bench Thread
Higher overclock.
7870XT (Tahiti LE) @ 1200 / 1600
Phenom II x6 1090T @ 4.1Ghz
72.85
Very pleased with that, sooooo much grunt in this year old £176 GPU. :D
1080p
4930k @4.8
Two 290Xs @1240/1625
Scoreboard updated gents.
Nice score Kaap and Gee.
I have got another run (I wanted to double check the settings) using higher clocks but all it did was increase the minimums but was still over 190 fps.:D
Not for the scoreboard.
1250/1625
Big jump in Fps for such a small nudge on the core.
That's why I re ran it.:)
The problem with the bench is not GPU grunt but CPU bottlenecking. 4 cards do scaling really well on this right up to when they hit the CPU bottleneck meaning two cards can out do four.:eek:
4 x 290Xs @1000/1375
4930k @4.8
1080p
1600p
Same settings
That's something you don't see often, a higher score at 1600p.:D
2 x 780's @ 1333/1700
4770K @ 4.6ghz
1080 dual card:
Will have to get the CPU clocked up, have a feeling something is holding them back, ~40mhz less then the highest pair of 780's yet near 30fps worse off.
4770K @ 4.6ghz
1080 dual card:
Suffering the same fate as me i see, cpu bottlenecked. We'll never stand a chance on this one unless we have a 6 core. You might get a better score by lowering your gpu overclock. :)
And on the scoreboard. :)
You can't judge it by that run. If he can do a run around the same clocks that I ran mine, then we can cross reference.
Why? Why did you leave x79 in the first place?
Tbh I was completely disgusted with the lack of progression in any direction IB-E offered, IPC perf was about 5% better then SB-E and the IMC gave about an extra 50-100mhz. Hopefully X99 this year though :D
I wasn't referring to your run. I was just saying that to get around the bottleneck at 1080P you need a 6 core. Kaap disabled two cores of his cpu at 1080P and lost a chunk of performance on 2x290x's at 1080.
I know you wasn't. I'll get scotty to run his card's and 4770k at the same clocks as my 3960 and see how his scores compare to mine.
