- 29 Aug 2010
- Cornwall
Also that statement seems to suggest that AMD have ruled out or given up on multi-vendor support for Mantle.
I think it was to be expected that Mantle would be quicker and could react faster as it can be more specific to AMD hardware.
So Mantle has the advantage of being a bit faster and more reactive/responsive to changes as well as possibly being ported to Linux (which would help but not immediately mean games work on Linux).
Where as DirectX has the advantage that it supports a much much larger range of hardware.
Mantle will be backed by AMD where as DirectX 12 will be backed by Microsoft and mostly likely Nvidia and in all possibility Intel and maybe even AMD.
I guess the real question will be what developers decide to support. They may well use both or they might just use DirectX 12. I can't imagine too many will ignore their Nvidia (and Intel) customer base and just use Mantle. So I guess that's probably another plus to DirectX, it could well be the ONLY API a developer uses/supports where as Mantle is mostly likely to be an extra API they add in, IMHO.
