From my research I found that raising the FSB came at a much lower temperature than hitting the multi. So basically for my 4.9ghz bench stable (and I ran the torturous Asus Realbench 2.0) I could only achieve it with a balls high FSB and my 20.5 multi. If I raise my multi any more my CPU becomes unstable and temps will soon see the PC locking up.
I was given some advice the other day from a mate of mine who is a bit of an expert with overclocking and he basically told me (this was for my Xeon but I would imagine it's similar in practice to AMD) that I should lower my mutli to the lowest setting (this is a Xeon 1366) and then start cranking the bus at 5mhz intervals. Once I fail to post or get into Windows take the highest stable setting and then start working on the multiplier.
lol
and also temps, house temp during tests was 20c ( this is idle temps in pic) will post max temps after more tests gaming ect.
hey guys im back at last! been working away forever finally back at base. (some may have seen my steam active my son is the culprit therelol
hi to all the new faces
so been playing with my clock speeds again and managed to up my 4.9ghz to the magic 5ghz, so far so good stable as im writing this currently running more test for longer periods to see if it fails, have gamed with it a little and touch wood she is holding up.
ran cinebench and broke the 800 mark 812 to be exact see below
[/IMG]![]()
also here are voltages (i managed to get 1.46v i was surprised but at current stable on that i was mega surprised by this, but hey it works, and every clock i have posted has had low voltage compared to most on here must have top chipand also temps, house temp during tests was 20c ( this is idle temps in pic) will post max temps after more tests gaming ect.
[/IMG]![]()
I see the thread is still going strong and helping people along never thought it would grow this big!
back now for a while so will be around a lot to help out
peace dudes![]()
Wb famerboy! Long time no see.
Hi farmer boy. Those cine bench results are impressive almost on par with a bumped up 4770k.
In speed fan how do you rename all the different temps and fan speeds to which components they are?
Cheers, Damien
I didn't have to as I know my pump speed and all my fan speeds
and...
Been having a fiddle tonight..
Annoyingly, my cinebench score goes up from 777 to 802 just by going from 4.9 to 5Ghz, while only going from 768 to 777 from 4.8 to 4.9, grr
Double post, sorry
Nice to meet you
Been having a fiddle tonight - trying to get 5Ghz stable. Currently at 1.48v but doesn't want to pass realbench
a 9 series slipped there net here i think hehehecinebench is ok but i can run one test after another and get different results each time :s lol
lowering multi and uping fsb worked for me to get cpu stable, that and i believe my chip is a rare egg i seem to be able to get high clocks at low voltagesa 9 series slipped there net here i think hehehe
