Biggest mistakes when building a PC
21 Jun 2010
infornt of my PC
Hi,
Having build a lot of machines over the past 25 years, I have my own ways of building.
I just wanted to know what tips other people utilise to avoid making mistakes that are either time consuming or damaging to parts.
Probably the most well known for a first one:
Always ground yourself.
Double and triple check the parts are correct and will fit into the case. (Made this mistake once)
Take your time when building, if something isn't going right or fitting take a short break and return with a fresh mind.
My sort of tips anyway, some may be common knowledge though.
Out of curiosity, does anyone actually know of any instance where not doing this has broken anything? I've played with the hardware of quite possibly hundreds of PC's all without grounding and never once had a single issue. I've never met anyone that still uses any kind of grounding strip nor have I ever heard of static actually damaging anything.
I'm not saying it's bad advice, I completley understand it's the correct thing to do, I've just never come across not doing it actually causing any issues.
Rule nr 1
Never use. ammer while building pc
NR 2
Mixing a lot of old thermal paste will not do the job
Nr 3
Dont shop on ebay to get cheap stuff u will rnd up paying more
Nr 4
Attention to details and cable managment, no one wants octopus in the case
I only touch metal before
I had case when someone didnt use antistatic package when posting gpu and it arrived broken
Don't overdo thermal paste and it it everywhere, I've had a few oh sh!t moments of trying to gently get some paste off the contacts of the Cpu and off the motherboard, not very often mind :p
And check connections and make sure ram is seated properly before freaking out
Stuff that doesn't fit together due to physical sizes is the main mistake I've made - its impossible unless someone else has had the same problem and posted info online to work this out sometimes though.
The other one is overlooking thermal paste - way too often the stuff I have is too old or I've lent it to someone and not got it back or just ran out and forgot and the build stalls til I've ordered some.
Bit of a classic brainfart today, transferring my old x58 system into a new case. Removed it all from the existing case, cleaned it all till it was spotless. Got everything into the case and screwed into place, only to realise id forgot to put the mobo i/o shield into the new case.
Worst thing was id taken the old case and fired it into a skip at the local recycling depot. Thankfully it's a few hundred yards from my house so retreiving it was easy.
my things:
#1 - take your time
- don't built on carpet
- use a cooler with thermal paste pre-applied
- double check motherboard standoffs
- don't touch contacts
- hang the cables out the back and test the rig before tidying the cables
I've done that more times than I can remember. :rolleyes:
Misplacing stand-offs and killing the motherboard...or not using them at all and killing the motherboard.
Installing a cooler with no thermal paste. The guy who's PC I fixed cleaned the fresh, new TIM off before installing the cooler.
Remembering that only the inside of an anti-static bag is anti-static.
Install the power supply first and route the cables before the motherboard goes in. Remember that the space between the motherboard and case is good cable routing space.
Ahhh some good ideas there, especially the PSU in first so you can hide the cables.
On a couple of builds for myself, I had instances where the i/o shield just would not fit so I didn't bother. As the PC lived under a desk that, no one ever went behind it and it was not possible to drop anything in side it. It never caused a problem. However I can understand the frustration of discovering you havent fitted it once you had build the PC.
Careful with your thermal paste, i put on way too much once and ruined a CPU and mobo. Fortunately it was just some cheap ones.
Check all the connections on the mobo and check if something is empty should it be. Missed the 4pin CPU and spent too long trying to work that one out.
Know where connectors are and the orientation needed before you fix something in place.
I built my new PC last week and installed a Corsair H100i and intended to take note of the fan connectors positions before I affixed it to the CPU but forgot. Spent 5 mins with a torch trying to ensure I didn't break the fan lead connectors when I connect them.
Haha - been there done that!
You need to chill out when building a PC.
Prepare some beer in advance, just don't spill it all over the hardware.
The pc won't like it, even if it's polish one.
If you feel like swearing a bit to blow off steam, go ahead.
Your neughbours will understand or even aporeciate, you are teaching them new words in foreign language after all - for free !
1) Cross check the compatibility of your parts beforehand (especially Mobo/CPU/RAM)
2) Check energy requirements of your setup (online tools can do this) and make sure you choose a PSU that can handle the requirements. I usually add on an extra 25% to the number for safety/future proofing.
3) Usually easier to mount CPU/RAM before installing your motherboard, especially if case is tight on space. Depending on the type of CPU cooler you have, you could also install this beforehand.
4) When mounting a motherboard, make sure you haven't installed any unnecessary mounting screws on the case that can touch parts of your motherboard which aren't meant for mounting. Had a mate who rushed this and overlooked it, leading to a short circuited motherboard soon after.
5) Always check your CPU cooler is mounted properly, sometimes it can be hard to tell with more fiddly coolers. Nothing worse then having temperature issues taking a toll on the CPU for something as silly as this.
6) If your case doors won't shut properly without a silly amount of force then reconsider your cable management, no reason to put additional stress on the chassis/parts.
7) Don't ever force a CPU into it's slot. If it doesn't go in seamlessly with no effort, then chances are it's orientation or even chipset is incorrect.
8) Hang on to spare parts/cables/etc you never know when they will come in handy
9) Any part that produces heat should be exposed to some sort of airflow. Last thing you want is a hotpocket
10) When setting up fans be sure to think about your cooling strategy. Don't have heat recirculating within the case
11) Avoid using ducktape for cable management, zip ties are easier to manage and won't leave adhesive over your cables (especially after a long time of use in a hot system)
12) Whilst tight cable management is good, avoid having cables so tight that there is noticeable tension on parts/connectors. Over time this can cause issues. Leave a bit of slack on the cables
Most stuff has been well covered.
One other minor thing, make sure things like the sata cables and USB 3 headers are plugged into the motherboard before you put in the graphics card especially if its a big card, a lot of GPU's are longer than the board so they cover the sata ports which makes them difficult to plug in after. Same with the 8 pin power plug, make sure thats plugged in first before you fit something like a big air cooler.
