AMD Radeon R9 295X2 8 GB reviews.
Impressive piece of kit, 8GB also a nice touch, decent start price which will no doubt come down in short order, I reckon my hand would be tipped at around £850 per card.
Nothing negative to say, a first for a new card launch and the first time an AMD Dual-GPU card has shipped un-compromised from its single card sibling, it even has a few extra bells.
With only 2 8-pin connectors I could easily place two of these into my rig without it looking like spaghetti junction.
Power use is never irrelevant. It's using an extra 250watts over a GTX 780Ti SLI setup and still losing in a lot of benchmarks. That's very significant. The Ti setup would be cheaper as well.
You making a massive exaggeration of it as usual, it uses 80 Watts more (entire System) given that it has water pumps ecte... its bound to use more power than one that doesn't. Its also faster than those two 780TIs
http://www.pcper.com/reviews/Graphi...-Card-Review/Power-Sound-and-Closing-Thoughts
If you are going to buy one of these, power is irrelevant, as is it using water cooling.
It is expensive though!
Power is never irrelevant. A card that uses more power means a higher energy bill. That said, a dual 780 card will use comparatively similar power levels unless they drop the clocks on it.
You honestly think extra few hundred watts or few of tenth of quids per year matter to people who are dropping over £1,000 on graphic card? :p
I have to say i was surprised at the performance the 295x2 offers. Even more surprised when i saw it marginally faster than 780TI SLI at 1440P and much faster at 4K when looking at the following reviews from Pcper and HardOCP.
Also Lol - Damn yanks saying Ray Deon.
Good stock performance which is impressive but it will be limited when overclocking and I don't think it will be able to match a pair of 290Ps.
As to competing against 780ti's, some of the reviews may show some nice results but the reality is a couple of very overclocked 290Xs can not match the 780ti's doing the same.
A lot of people don't game with two cards heavily overclocked though. One thing to consider in these reviews the 780TI's were up at 84c+ temps whilst the 295x2 does not break 60C and does not go much higher when adding 10-15% overclocks. The 295x2 is also quieter. However i agree in principal with what you're saying if both cards are water cooled.
HardOCP also noted the new Nvidia drivers allow the 780TI's to reach 87C now before throttling. :)
lol..:D
A lot of people don't game with two cards heavily overclocked though. One thing to consider in these reviews the 780TI's were up at 84c temps whilst the 295x2 does not break 60C and does not go much higher when adding 10-15% overclocks. HardOCP also noted the new Nvidia drivers allow the 780TI's to reach 87C now before throttling. :)
So much for overclocking the 780TI to beat the stock 295 x2.
NVidia cards are easy to keep at 80c even with big overclocks and if you can not be asked to change the fan profile to do this, all you have to do is raise the limit at which the cards throttle to 90c.:D:)
