FIFA 14
He might work in a two but I worry for his work rates and presence in a two. Not to say it won't work just that I'd rather use someone like Modric in a two as my more attacking CM.
I used him as a CM in a 433(4) and he was really good. Looks like a perfect CM for a 433(2) if you can get him in a squad you like :).
Anyone used Neves SIF? Stats look insane for the price but I'm worried his shooting will go to waste as a left footer on the left.
He should be fine, not sure on his weak foot off the top of my head, but long range is where he is deadly, either foot is good, and if in close a lefty on the left with a strong foot shot across the goal seems to work pretty well this year, not OP, but effective.
I am absolutely murdering teams this evening but can't put the goals away. So frustrating. I have Tevez, Balotelli and Di Natale in the rotation so the fault definitely lies with me!
Gone with this. Not the strongest Brazil team you're likely to see but I have high hopes for the wings :D. Plan on adding Paulinho, Fernandinho, Ramires, Silva, another CB and Willian at some point when I get have coins.
Try Juan Jesus - hes been immense for me - also consider that a few of those Brazil CBs have great GK links to avoid Brazilian GKs...
ps3ud0 :cool:
ps3ud0 :cool:
Any suggestions :). I know I can use Courtois with Jesus and Miranda thanks to Hernanes and Maicon. I can't use Neuer because 60k and Sirigu with Silva could work but again Silva is out of price range at the minute.
Well youve got Luiz-Cech; Miranda-Courtais; Jesus-Handanovic. If you put Jesus as RCB, you should be able to put any Brazil CB at LCB and their GK and 10 it up if I worked that out correctly...
ps3ud0 :cool:
Anything but Louise! Never used such an error prone player before!
Handanovic! He's been great for me in my Serie A squad, will probably go for him. Alves isn't so bad to be fair so I can use him when needed.
Cheers!
i can let you try some of my brazil players out if you like, just let me know. you can view my squad in game
i like to see Thiago Neves against Willian :)
ps3ud0 :cool:
talking about squad, nice brazil trades going on with you. you only paid for 2 players :P
ps3ud0 :cool:
As long as one CB has a double link somewhere, you can use the team GK of the other CB, if he used Courtois, Dante would be on 7/8 chem depending on loyalty, if he used Neuer, both Miranda & Dante would be on 10, as would Neuer.
Yeah but Jesus at RCB links with Maicon so whatever LCB and GK combo Jesus should be fine - especially if you have the Hernanes link too...
EDIT: Reread and you are just saying what I said...
ps3ud0 :cool:
just have the following:
Luiz - Dante
Cech or neuer in goal
Who at fullback & cm positions? You're assuming that they have a strong link elsewhere? Or just forgetting they need one?
Only something like
--------- IF Alex ------ Silva ----------
---------------- Sirigu ----------------
Is a viable suggestion without knowing if there are any external strong links out of the CB-CB and CB-GK links.
Do I need to get the whiteboard & crayons out? :p
