- 25 Nov 2011
- The KOP
Nice now we need crysis 4 trailer haa
BIG NEWS!!
CRYENGINE To Support Mantle, AMD Gets Another Endorsement
Welcome back Matt - great news!![]()
Was that using a fraps output or the direct bf4 output? I have no idea if the internal engine based tests would be more accurate or not, but they do lack timed bench options.
After seeing pgi's frame latency testing on 780 SLI @1080P i decided to hunt down the program he used and test it on Mantle at 1440P instead of 1080P. I also tried each of the three different Mantle frame pacing implementations to see if i could feel a difference. I couldn't.
2 = Extreme
1 = Standard
0 = Disabled
Frame Pacing Method 2
Frame Pacing Method 1
Frame Pacing Method 0
2 = Extreme
1 = Standard
0 = Disabled
2 = Extreme
1 = Standard
0 = Disabled
EDIT - REALISED I WAS RUNNING THESE TESTS IN POWER SAVING MODE. CPU @3.9GHZ LOCKED AND DRAM AT 1600MHZ.
Will have results of 5.2ghz vs 3.9ghz Mantle shortly.
Great data and testing here guys, very interesting.
Did find this nugget for those wondering what the advances were on older GCN 1.0 cards with the latest driver and framepacing from the Anandtech R9 295x review.
http://www.anandtech.com/show/7930/the-amd-radeon-r9-295x2-review/4
Hi Matt,
I had my hand in my pocket for a 4k monitor but this article has changed my mind. Bit risky on expecting smooth performance on a 7990 and a 4k monitor as essentailly all monitors are seen as 2 screens and frametime smoothness still suffers under multimonitor setups.
Bit annoying as I was looking forward to when these £500 Sammys went 'In stock' or the £600 asus.
What to do?
Hi Matt,
What to do?
