Dirt Showdown Bench Thread
I know you wasn't. I'll get scotty to run his card's and 4770k at the same clocks as my 3960 and see how his scores compare to mine.
Furry muff. Kaaps runs was four cards so maybe the difference won't be as big as i thought.
4 Core Shocker
I just ran my 4930k with 2 cores turned off so it was near enough a 3770k @4.8
Below are some runs I have done on 4 cores, if you compare them to the 6 core runs I did earlier there is quite a drop in performance.:eek:
4 stock 290Xs @1600p
4 stock 290Xs @1080p
2 290Xs @1230/1625 @1080p
As you can see from the pics I have lost 15 or more fps by turning off 2 cores.:eek:
Well, its good to know my 6 core has use :D
I might turn two on my cores off, see what happens. Should i?
You might aswell Humbug for a comparison
Its made no difference, overall CPU usage is higher but the GPU is still solid at 98/99% and the score (bar margin of error) is unchanged.
Plenty of head room in it :)
Some scores from LtMatt
2700k 4.4ghz
1600mhz 9-9-9-27-2T - stock seconds
290 crossfire @975/1250 stock
2700k 4.4ghz
2133mhz 9-10-10-21-1T - tight seconds
2700k 5.27ghz
2133mhz 9-10-10-21-1T - tight seconds - BCLK 102.5
290 Crossfire 975/1250 stock
