corsair 750D power switch?
13 Nov 2013
I have just completed a new build with this case, everything seems OK, except the power swith on the front panel does not depress enough to turn on the switch behind it.
If i take the front panel off and hit the switch it powers on fine.
Anyone else have this problem, have I done something stupid?
reviving this old thread because i've the exact same problem with mine. did you find a solution?
I am going to buy one, should I hold off? Sounds like a design fault.
Not sure....not seen anyone else saying they have been having that particular issue ...so might just be a one off.
So yeah ....its a lovely case, big ...but very nice ..I do like Corsair cases though ..so go for it...buy one :)
it's an amazing case don't let that small issue put you off.
it only seems to be a few of us that have this particular issue. I don't regret getting it at all, it is just a bit annoying but I worked around it
If you haven't found a solution or a work around for the power button.. I'd sugget just send a RMA request for the front fascia and get that piece replaced. Corsair.force.com.
Just rebuilt my system last night in a 750D and had this same issue. All connected up correctly but it wouldn't power up. Switched it all off and removed the front panel, reattached it and now all working fine including power led.
Just saw your reply.
I've just sent a RMA request. thank you
