Dirt Showdown Bench Thread
Caporegime
OP
12 Jul 2007
United Kingdom
I know you wasn't. I'll get scotty to run his card's and 4770k at the same clocks as my 3960 and see how his scores compare to mine.
Furry muff. Kaaps runs was four cards so maybe the difference won't be as big as i thought.
4 Core Shocker
I just ran my 4930k with 2 cores turned off so it was near enough a 3770k @4.8
Below are some runs I have done on 4 cores, if you compare them to the 6 core runs I did earlier there is quite a drop in performance.:eek:
4 stock 290Xs @1600p
4 stock 290Xs @1080p
2 290Xs @1230/1625 @1080p
As you can see from the pics I have lost 15 or more fps by turning off 2 cores.:eek:
25 Jun 2011
Aberdeen
1080
Single 780 @ 1359/1700
4770K @ 4.9ghz
Man of Honour
21 May 2012
Dalek flagship
Some scores from LtMatt
2700k 4.4ghz
1600mhz 9-9-9-27-2T - stock seconds
290 crossfire @975/1250 stock
2700k 4.4ghz
2133mhz 9-10-10-21-1T - tight seconds
2700k 5.27ghz
2133mhz 9-10-10-21-1T - tight seconds - BCLK 102.5
290 Crossfire 975/1250 stock
