Go ahead, increase it.
What are you overclocking and what are the other settings?
Power Target basically givers your card more watts to deal with, it helps to stabilize OC a lot. you can usually tune the power target to max, as the card will only take what it needs.
Well I put it upto 150%.
But when I started up elder scrolls my screen went blank. Everything froze. Then it recovered and Elder scrolls crashed, Is that a driver crash??
It is indeed a driver crash and reset. Up vcore.
What do you mean by Vcore.
Do you mean GPU voltage? At the moment it's at 1250 Mv.
I can use afterburner sorry.
But the core voltage is locked?
Locked via afterburner? May be. Its an asus card so i guess they tie you into GpuTweak. If you're saying that your card is voltage locked, then you've reached the limit on the core then.
Only locked on afterburner and yes its a asus card.
What should I rise voltage too? Paranoid about rising it as a review with the same card got even higher clocks from me on standard voltage? :S
You'll be fine up to 1.3v don't worry.
Just keep temps below 80C and you'll be fine.
Thank you! Will do that now and try elder again.
You have this card right?
http://www.overclockers.co.uk/showproduct.php?prodid=GX-330-AS&groupid=701&catid=56&subcat=1752
You'll probably be fine with the voltage up to 1.35v or higher on that card. It has good cooling. One of the premium brands.
Yup thats my card, Are you sure to push 1.35v? I mean fans are at 44% and its sitting at 79c but it stays there while playing elder scrolls online. Has no issues keeping it below 80c.
