The two are around on par, but 290 still has 1GB more vram and cost quite a bit lesser than the GTX780...but it'd probably be wise to avoid the MSI Twin FrozR cooler/Gaming models as there seem to be quite high probability with fan problems; for the GTX780 you get less vram and cost quite a bit more, but it is probably more likely that you might not run into issue that might require you to fiddle around to solve.Is the 290 non X version not better performance than the 780?
Want to get something that will last me for a bit.
780/780ti every single day of the week. Your best move was selling the 280, now get a 780/780ti, you'll never go back.
So should I just get the 780 over the ti as the performance is not much
On average the 780ti is roughly 20% faster than a 780. Also, with the new 337 drivers, they simply laugh at the 290's.
If you want to get into that the 290 simply laughs at the 780TI with Mantle.
Lets not get into AMD's custom low level API vs Nvidia's DirectX Duck-Tape Hacks.
are you using a 290 or the 290x?
I'm confused now
