I thought it was a trap injury?
He is still handsome.
Captain planet - - - -95-140-160---[85]---395
Feels like I'm starting all over again. My weight has dropped a fair bit, I feel weak.
Couple of issues with the wraps...
Firstly, why are you using them?
Secondly, there shouldn't really be any equipped lifts in the table. I know there isn't a rule against it, but there should be. Otherwise, I could just through on a slingshot and post an inflated bench number. Sure, I could declare the use of equipment, but it becomes a meaningless and unrelatable quantity.
Secondly, there shouldn't really be any equipped lifts in the table. I know there isn't a rule against it, but there should be. Otherwise, I could just throw on a slingshot and post an inflated bench number. Sure, I could declare the use of equipment, but it becomes a meaningless and unrelatable quantity.
It's ok - there is no video.![]()
