Guys
Our Corsair refurb coolers were a hit at the crazy price points we offered them at.
This offer is even sweeter.
Brand new, full warranty, all accessories.
We have a few units in stock currently which will no doubt sell very quickly, but the new stock is due to land around mid week next week.
Once current stock runs out we will switch the listing over to pre order to allow people to grab coolers at the new price.
Stock for this deal is LIMITED. Once we run out, I cant see it happening again.
Antec Kúhler H2O 650 Liquid CPU Cooler @ £29.99 inc VAT
The Antec KÜHLER H2O 650 delivers high-performance liquid cooling for your CPU in a quick, easy-to-install package.
The Antec KÜHLER H2O 650 delivers high-performance liquid cooling for your CPU in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The extra large pump circulates coolant through optimized water channels, while easy-bend flexible tubing allows the KÜHLER H2O 650 to be installed in nearly any orientation. In addition to easy installation, a powerful PWM fan pushes air through directional blades and channels it through the radiator for optimal cooling. Included in the box is an air duct that reduces static pressure which in turn, allows air to flow out of the case efficiently. Lastly, integrated firmware automatically adjusts fan speed and changes the RGB LED based on temperature. Engineered for maximum performance, the Antec KÜHLER H2O 650 delivers liquid cooling performance at an air cooling price
Features:-
- Copper cold plate is optimized for thermal conduction
- Extra large pump and integrated PWM fan were engineered to cool the radiator efficiently
- One Integrated PWM fan automatically adjust fan speed based on temperature. Built-in directional
blades focus airflow through the radiator
- RGB LED illuminates your case and changes color to
indicate CPU temperature
Specification:-
- Fan Speed: 600 – 2400 RPM
- Radiator Dimensions: 159 mm x 120 mm x 27 mm
- Fan Dimensions: 120 mm x 25 mm
- Cold Plate + Pump Height: 1.0” / 26 mm
- Tubing Length: 11.8” / 300 mm
- Cooling Liquid: Safe, environmentally-friendly, anti-corrosive
- Warranty: 3 years
Was £47.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Antec Kúhler H2O 950 Liquid CPU Cooler @ £44.99 inc VAT
The Antec KÜHLER H2O 950 provides cooling for your CPU in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. In addition to easy installation, dual powerful PWM fans pushes air through directional blades and channels it for optimal cooling.
The dual 120 mm Pulse Width Modulation (PWM) fans and extra large pump ensure quiet, efficient cooling, while the double wide radiator is equipped to cool any high performance CPU on the market. An integrated fan, pump, and radiator allows coolant to circulate through the radiator at a higher velocity which in turn increases cooling performance. Lastly, the included Antec Grid™ software helps you monitor and control the KÜHLER H2O 950 and allows you to customize its stylish RGB LED. Take your PC’s Quiet Computing™ to the next level with liquid cooling performance at a price that rivals aftermarket air coolers.
Features:-
- Extra large pump and integrated fan were engineered to cool the radiator efficiently
- Two Integrated PWM fans automatically adjust fan speed based on temperature. Built-in directional blades focus airflow through the radiator
- RGB LED illuminates your case and changes color to indicate CPU temperature
- Included software provides essential tools to control and monitor the KÜHLER H2O 950
Specification:-
- Fan Speed: 600 - 2400 RPM
- Radiator Dimensions: 159mm x 120mm x 50mm
- Fan Dimensions (2 Total): 120mm x 25mm / 4.7" x 1.0"
- Cold Plate + Pump Height: 1.0" / 26 mm
- Tubing Length 11.8" / 300mm
- Cooling Liquid: Safe, Environmentally-friendly, anti-corrosive
- Weight: 1.3kg
- Warranty: 3years
Was £69.95 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- Warranty: 3 years
Was £47.99 Inc. VAT
ORDER NOW
Features:-
Specification:-
- Weight: 1.3kg
- Warranty: 3years
Was £69.95 Inc. VAT
ORDER NOW
