- 15 May 2013
- north east
needs more birds
What I like is being able to get the application to reboot the system into Safe Mode without having to adjust anything in Windows 8 or press F8 for Windows 7.
That was fixed LtMatt, it was a registry problem in an earlier release
Display Driver Uninstaller 12.6.4 (04-11-2014)
Changelog:
-Modified some msgbox.
-Do NOT auto-select the Intel card when a Nvidia or AMD card is also present
-Close the application when we click YES to the update question.
-Fixed a bug on win 7 that prevented opening the browser when clicking yes for updates.
-Workaround folder permission when they cannot be removed. AMD and Nvidia.(permission / readonly).
-Translations New/updates (Dutch : Elite3540)
-Minor general fix / enhancement in the code.
-New Credits to nedooo` for the time he took finding that Avast DeepScreen Could cause issue with DDU.(unfixed, may need to contact Avast about this)
Its very good. I still find it best to uninstall the driver properly first though, then restart into safe mode and run this. I had an experience of running this first to uninstall AMD drivers without doing it myself properly first. When i tried to reinstall new AMD drivers they appeared to install fine but came up with an install error. Likely a missing reg entry or something, not sure. So uninstall normal way first, then run the tool. Works everytime.
Display Driver Uninstaller 12.7.0 (04-23-2014)
Changelog:
-Set a timeout value of 2 secs when checking for updates.
-Fixed a bug that could cause some other device to get removed. Thanks to "Extraordinary" for the time he took with me testing.
-Added a warning messagebox to warn the user of the DDU automatic boot into safemode.
-Do not check for removing the Upperfilter of Nvidia Optimus when Cleaning AMD videocards..
-Updated driverfiles.cfg for the Catalyst 14.4 RC1 release.
-A little more cleaning on the AMD side. (almost perfect already tho.)
-Log is cleaner now.
-Fixed a possible hang in the nVidia Optimus cleaning section.
-Korean Language update. Thanks to: Zames Dean
-Translation updade: Hebrew , Thanks to yosef019
Download
Has that annoying there is an update pop up been fixed even when you clicked the link and installed the latest?
