I've seen some stunning custom loops in Parvum cases and its making me want to try it. I'm not sure if I should look at the D5 or the CM Eisberg block, but eventually, id be looking to WC my CPU and 2x 7970.
Budget is no more than £350-400, looking for black fittings and red coolant. Not looking to buy immediately, will be close to end of this year, but need recommendations. Will also need to start saving, this is what I've come up with so far, fittings...I'm unsure about which would suit.
YOUR BASKET
1 x Cooler Master Eisberg Prestige Jetstream CPU Liquid Cooler £89.99
2 x EK Water Blocks EK-FC7970/R9 280X CSQ £79.99 (£159.98)
2 x XSPC EX240 120mm Radiator - Black £37.99 (£75.98)
2 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25 (£50.00)
1 x EK-FC Bridge DUAL Serial CSQ Plexi £18.98
2 x Mayhems X1 UV Red Premixed Watercooling Fluid 1L £7.99 (£15.98)
3 x Primochill Primoflex Advanced Tubing 16/10 - Clear £5.99 (£17.97)
Total : £438.48 (includes shipping : £8.00).
Suggestions and recommendations are welcome
YOUR BASKET
