LuxMark 2.0 Bench Thread
29 Aug 2010
Cornwall
Yeah probably. Still though i like to make sure its stable for everything, even something like this. The way i look at it, it may eventually display small artifacts in games. Not sure whether id notice this or not, but id rather not take the risk. So rather than running -0.037v and -0.100mv i will now run -0.031v and -0.100mv for 24/7. I might see temps go up 1-2c or so, but id rather have that and complete stability.
in that case run it at the out-of-the-box clocks on out-of-the-box voltages...
EDIT
I mean obviously it's up to you, I'd just hate to see this being quoted as an OC testing tool from now on and people thinking they needed to be stable in this to be 'stable'.
29 Aug 2010
Cornwall
On the reference coolers? Lol no chance! I can keep decent temps with these settings and still maintain a 10% core overclock from a stock 290 Pro. ;)
I guess 'decent' temps is a subjective term... (I bet Kaap's definition of decent temps would be different to yours for example :))
I could argue with mine at stock (volts and clocks) I can keep decent temps (with a custom fan profile).
Caporegime
OP
12 Jul 2007
United Kingdom
Aha but you said you hate noise!
What temps and fan speeds? With these settings i can keep temps in the 80-85c range (depending on game played and if i use vsync or not and fan speeds from 50-55%.) I could keep it cooler if i used a more aggressive fan profile. That's with a 10% overclock as well.
29 Aug 2010
Cornwall
I do hate noise, but you didn't mention noise, you just said temps.
Also, I'm the one arguing that reference 290s are loud, you argue that they're silent.
I imagine Kaap would be panicing a bit if his cards hit 80-85ºC! I'd be surprised if Kaap's temps were much more than 60ºC?
13 Mar 2008
Ireland
Here's the results for my FirePro D700's in Windows 8.
In Windows 8.1 64-bit Enterprise
AMD FirePro D700 6GB x2
Drivers: Catalyst 14.4
GPU Clocks Default. Core 850Mhz Memory 1370Mhz
Here's the results under 2.1 in OSX
Drivers Default OSX 10.9.2
Clocks GPU 1 850Mhz
GPU recognised as 150Mhz, should be 850Mhz ( possibly a bug in Luxmark reading the second GPU in Idle state )
Caporegime
OP
12 Jul 2007
United Kingdom
I never said they were silent! I said they were not as loud as people make out, which they aren't. I did say they were silent at idle though, which they are. ;)
I doubt Kaap's cards go much over 50C tbh.
:eek:
Blimey that's going to keep my busy for a while.
EDIT
Can you list the gpu clocks and driver used please.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
I don't know much about Tera-Flops I am afraid.
Isn't that how the guys at AMD HQ are describing the Titan Z.:D
Its the Raw Floating Point performance of the GPU. just like the CPU's performance, your i7 39## probably has about 180 Giga-Flops of processing power.
1000 Giga-Flops = 1 Tera-Flop
Top 3 GPU's
R9 295x2 = 11.5 Tera-Flops
R9 290X = 5.6 Tera-Flops
Titan Black = 5.1 Tera-Flops
Titan-Z does not exist :p
Man of Honour
21 May 2012
Dalek flagship
I don't think mine have ever been over 45c on water.
This is what they are doing at the moment.
29 Aug 2010
Cornwall
url])
I thought 60ºC was being generous, but you do have 4 and I've no idea how hot 290Xs actually run (I know reference runs hot, but are the cards hot or the cooler underperforming).
Also, I wastalking about what you'd consider 'decent' temps not 'good' temps or 'excellent' temps let alone what temps you actually get!
13 Mar 2008
Ireland
EDIT
I edited my post, but there's the extra details for ya
Clocks GPU 1 850Mhz
GPU 2 recognised as 150Mhz, should be 850Mhz ( possibly a bug in Luxmark reading the second GPU in Idle state )
Man of Honour
21 May 2012
Dalek flagship
With air cooled cards I don't really worry that much as long as the card is designed to run that hot and does not throttle. My GTX 690s are a good example when gaming the primary core can hit 90c and the other 3 anywhere between 80c and 85c. I don't worry about that as the 690s are built to run at those temps (the rest of the 6 series are a bit wimpy with temps). What can cause a problem is the heat generated can cause problems for the rest of the PC (motherboard/CPU/memory/SSDs) so it is important to get rid of it. Going from air to water on my 290Xs did wonders for the rest of my PC, the cards were ok on air but the rest of the PC was suffering.
29 Aug 2010
Cornwall
Another thought, although more work for LtMatt, how about a section for CPU+GPU?
I'd also be interested to see just the CPU results, but not really the right sub-forum for that. CPU+GPU could go in either though, I'd guess a lot of GPU benchmarks are affected by CPU anyway.
Caporegime
OP
12 Jul 2007
United Kingdom
I do have a reserved section so that could be added at a later date.
Man of Honour
21 May 2012
Dalek flagship
This is my 4930k @4.0 on it's own
If I run it at the same time as the 290Xs it only adds about an extra 70 points to the score the cards get on their own. I think most of it's processing power is used driving the GPUs and so there is little left over to add to the score.
