LuxMark 2.0 Bench Thread
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Here's the results for my FirePro D700's in Windows 8.
In Windows 8.1 64-bit Enterprise
AMD FirePro D700 6GB x2
Drivers: Catalyst 14.4
GPU Clocks Default. Core 850Mhz Memory 1370Mhz
Here's the results under 2.1 in OSX
Drivers Default OSX 10.9.2
Clocks GPU 1 850Mhz
GPU recognised as 150Mhz, should be 850Mhz ( possibly a bug in Luxmark reading the second GPU in Idle state )
Dual D700's, is that the new MAC-Pro?
Caporegime
OP
12 Jul 2007
United Kingdom
Crossfire 290's @977/1250
14.4 RC1
Room
Score - 2748
Two points Lamb Shanks, two points! I will make that up somehow, even with lower clocks. Muahahahah!
I changed to the beta drivers and got a few extra points.
Complex - Score 2746
290 Crossfire @975/1250
14.4 Beta
Caporegime
OP
12 Jul 2007
United Kingdom
Read it and weep Shanksy boi. Had to use Windows 8 diagnostic startup to get these scores. Can't beat you on Complex though, will have to settle for a draw, though i suppose i theoretically take 1st place as i have slightly lower gpu clocks. :p
14.4 Beta is definitely scoring higher than 14.4 WHQL for me.
290 Crossfire@975/1250
14.4 Beta
HDR Ball
Sala Medium
Room Complex
29 Aug 2010
Cornwall
Been having a quick play with this.
I've noticed a few things...
  1. Uncle Petey that's a good score, my 7950s don't come close to that! (Although they're not clocked nearly as high)
  2. While I can't beat Humbug's Single card score, I think my 7950s probably beat him on Bang-for-Buck based on their score. I think Uncle Petey's 7970CF probably beat that though, depending on how much he paid.
  3. The application seems to detect and display the clocks you were using when you loaded the application, however the score reflects the clocks you were actually running.
Caporegime
OP
12 Jul 2007
United Kingdom
Yes it does not detect core overclocks so its important for people to list them. Scores definitely improve with overclocking though.
How do you find TriXX?
I only use it on my 7770 system as it allows for 1.35v where as afterburner only allows 1.3v.
