Memory X58 chipset
14 Jan 2013
Horsham
Hey guys currently have 6 x 1GB of 1600MHz DDR3 Dominator installed. Which is a bit of a fail because I have no more available slots on my ASUS P6T for upgrade.
To run the latest & upcoming games should I be looking into more memory?
Also if someone could please explain why I am seeing 2 x 4GB DDR3 kits for sale, I thought DDR3 is optimised to run in triple channel?
Lastly, my board is able to run max of 2000MHz, should I be looking to get this speed RAM over lower speeds or are the benefits marginal?
Not sure faster ram makes much or any difference when gaming. If it does, I have not noticed it.
Do you need more ram, are you running any applications that requires or would benefit from more ram?
Are you having any ram issues whilst gaming?
your board can support tri channel (3 sticks) and dual channel (two sticks) of ram
I wouldn't go above 2000mhz tbh,i could only manage 1800mhz with 6gb,12gb would need more cpu/vtt voltage
but yes you could run 8gb dual channel if you wanted to
6GB if RAM shouldn't really be an issue for gaming. You'd be better served trying to clock your CPU a bit more and aim for 4GHz and think about a GPU upgrade.
No I don't do anything RAM intensive apart from gaming here & there, no issues whilst gaming either just thought I could maybe be bottlenecked by 6GB.
Where do you see this info? I'm looking at my board specs & can see nothing?
http://www.asus.com/Motherboards/P6T/specifications/
I am thinking of pulling the trigger on a Noctua NH-D14 + GTX 780/R9 290X but was looking for other weaknesses in my system aka RAM :P
x58 can support tri and dual channel,test with pulling one of the ram sticks out,look in the mb manual for dual channel configuration
it will tell you the slots to use for two sticks
if you want to use the noctua cooler then you'll need low profile memory or else the cooler will hit the ram
If you only use 2 sticks of DDR3 it can't run in triple channel, only duel, similarly of you only use one stick it will only run in single channel. Your board supports all three options, but you should run it in triple channel mode for best performance.
This has cropped up a few times but I'm seeing conflict of stories whether it will fit or not.
This video seems to show it clears, & the memory looks to use the same heat spreader as my Dominator.
https://www.youtube.com/watch?v=AU6W_YkqILY
Thank you.
Like someone else said, don't bother getting any memory faster than 2000mhz, it will be a waste of money, I was running an x58 up until the begining of this year, had 3 sticks of g.skill Ripjaws 2133mhz in it, they wouldn't clock higher than 1600mhz, it's all down to the cpu memory controller. If you want to carry on running tri channel then just buy 2 dual channel kits and put 1 stick away for a rainy day.
However if you go the other route and buy a new graphics card like the ones you suggested, you will find the bottleneck is actually your cpu and board, it will be the gfx card sitting waiting for instructions back from your cpu.
Interesting, even at (hopefully) 3.8GHz? If so which card would you recommend to be more suitable?
Do games utilise more than 4 cores these days?
I tested the theory myself, I had an i7 920 doing 4.3ghz on an x58 board with 2 x 270s in crossfire, not powerful cards I know, very mid range, I got approx 10 fps more running them on a z87 board with an i7 4770k doing the same speed.
Edit. Sorry, tested with benchmarks rather than games.
