Ok so First post asking for advice here
My current Pc is one that I've been either given or sort of made.
CPU - E5500 2.8GHZ
Motherboard - Unknown Fijitsu one of some sort
4 GB DDR3 (3.5 useable)
Win 7 Pro 32bit V
GTX660 Graphics card
1 x 170 GB hard drive (Partinioned before I got it)
Ive got a couple of screens running off it (1 HDMI and 1DVI)
Keyboard is just the stock Fujitsu one but its comfy to use
Mouse is RAT V3
I pretty much soley play World of Tanks with a few of the mod's running on it along with the normal net / Office / music etc
I currently only get at most 30FPS on graphics set to almost low, a couple on medium
Now I think that I defo need a new motherboard / CPU and proberbly a new OS to make it 64bit for better memory use.
I'm currently saving up money to remodel this - though I do keep wondering should I just buy a new PC?
I'm open to any advice and suggestion
Ideally I'd like to play the game on full settings - and also be able to play other things like War Thunder, World of Warplanes and when it egts released World of Warships?
No set budget yet but if possiable looking at brackets of either £500 / £750 and £850 at the top end.
Current PSU is a 600 watt one (I think) though its not modular etc and the case isn't massive - think its just like your normal off the shelf midi size?
Total newbie at this though I did do the memory / Graphics card swap myself and the Dos Prompt change for the memory ammount so happy to try anything - even build from scratch but that does daunt me
Thanks for any help avilable as well - I've read a lot of the project logs and the guides here and its all been really useful to try and think which way to go.
CPU - E5500 2.8GHZ
Win 7 Pro 32bit V
Mouse is RAT V3
16GB RAM isn't really necessary for gaming
