Crisp packets?
That is in no way true lol.
2. Have you ever had to use whatever is at hand to get the job done - food bag; banana skin; inflatable Turtles blimp, for example?
)Sod it, encase your flopper in concrete and dive off the top of the wardrobe.
do you crisp packet on first date?
sounds idealPlastidip protects coated items against moisture, acids, abrasion, corrosion, and skidding/slipping, and provides a comfortable, controlled grip. Plasti Dip remains flexible and stretchy over time, and will not crack or become brittle in extreme weather conditions. It has been tested and proven in extreme temperatures.
Wood: Seals and protects from weathering, and prevents splitting.
Metal: Reduces vibration, deadens sound, and prevents corrosion.
Glass: Shatter proofs glass objects (available in clear).
Also... Plastics, Rubber, Fibreglass and concrete surfaces!
NOTE: Surfaces which are non-absorbent such as metals should be primed using specialist Plastidip Primers.
are spray on plasters cheaper than condoms?
Wow i haven't laughed so hard for ages!
what ever next a can of coke or a pop bottle! maybe Mr kipling may make "exceedingly good condoms"
The situation is really not helped by morons like Amazon that won't sell condoms to under 16 for some mysterious reason. The prices of condoms are really ridiculous as well, hundreds of pounds a year!
An alternative method is to pull your skin forward and ziptie it
