Intel Rangeley (Atom server) availability
18 Aug 2007
Liverpool
I've been told by someone in the know in the pfSense community to try to source Intel Rangeley C2558 or C2578 boards/chips rather than go forward with my plan to use an AMD Jaguar/kabini A1 setup for my new hardware firewall/router build.
I'm struggling to find prices though I have come across a couple of business suppliers who have them available. Can anyone shed any light on the availability and pricing of this kit in the UK? The guy I spoke to seemed to think they'd be comparable in price to the AMD kit, but better for pfSense compatibility.
Thanks in advance. :)
I run pfsense on esxi on my 4 year old n36l microserver, and it's very happy. Low CPU usage even with squid on there.
Could be a useful workaround if esxi runs fine on the AMD setup.
Unless you make the right hardware choices for your Esxi host your not going to go very far with a pfSense VM
Better off sticking with a live "hands on" box IMO
I'm looking to build my own pfsense box... I was looking towards this MB
Intel BLKD2500CCE ... it has twin Intel Gig NICs and works straight out of the box. If you want a bit of expandability... look at these
Jetway JNF9D-2550 Fanless Dual Core 1.86GHz Atom Mini-ITX Board
and
Jetway JNF99-525 Long Life Fanless Dual Core Atom Mini-ITX Board
Both are more costly but use Daughterboard Expansion to add up to 3/4 further NICS for DMZ or Wireless AP etc
If you want away from Atom... consider a
Gigabyte GA-C1037UN-EU Fanless Celeron 1037U Mini-ITX Board... it has Realtek NICs but could be a contender ?
