Dualmonitor tool/program?
  • Thread starter Thread starter IC3
  • Start date Start date
IC3
IC3
3 Dec 2011
Is there a program which will allow me to do the following
- Disable extra monitors
- Allow navigationbar only on 1 screen
- Will work in the background
- Will startup with my system
I'm using maxiumum of 3 monitors, but 80% of the time only 2.
Pretty sure ultramon will do this for you. There is a free older version around I used (since paid for it) allows you to set boot profiles for monitors so would only boot with two enabled and the 3rd can be shortcutted to switch on off.
It does work in "background" as in it sits in the system tray if that's background enough for you?
I'll try this program today, currently I'm using 'DualMonitorTools-1.9'
If you using ATI, then CCC allows you to put start bar on one desktop.
To turn the montiors off, you could setup profiles or you just push the power button?
But the card keeps the 2d clocks, in my case 501/1400
