HOMECINEMA-PC 3930k@5204@2428 TRI 290@1100@1426 155.5fps 6505 1080p
HOMECINEMA-PC 3930k@5204@2428 TRI 290@1100@1426 115.9fps 4847 1440p
Thanks maaaaateWow, on the Score Board![]()
Hummy you forgot Matt. He should be up sitting next to me![]()
Nice score mate. Are you on water? What drivers were you using? I think my score looks a tad low for the clocks used.
His CPU, 3930K @4.9.
Do you get bottlenecking?
You need 2% to beat him, give it another go on Win 7I don't think so. He might be on Windows 7, so that could explain it. Never realised there was that much difference though.
How come results vary so much from card to card?
e.g. Top 780 - 4369
There are are some 780s around 2604
Just trying to work out if I buy another 670 and go SLI or sell mine and go 780
Quite a big difference in these two. Just the overclocks i guess
8, #3730 - 780 @ 1430 / 3944 - newhit
#2604 - 780 @ 1241/1782 - Kei
Because Newhit has a high end CPU with a massive OC, it gives him a boost in scores alone but then take his 1430Mhz clock and 1972Mhz memory compared to 1241Mhz and 1782Mhz memory, there is a massive fluctuation in scores.
Don't expect to get Newhit clocks though, as he is on extreme cooling![]()
Not a million miles away on stock cooling.
13, #3527 - 780 @ 1420 / 3704 - Geeman1979
True that Gee![]()
