what is the best possible graphic card i could get possibly for £350, is it the AMA R9 290 series? or can i get anything better?
2x GTX 670/680s/1x GTX690 2nd hand
or a 780 new eg:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-114-GI&groupid=701&catid=1914&subcat=1341
as alternatives
What resolution do you game at? what games do you mainly play?
what are the rest of your specs?
If you don't mind a bit of overclocking yourself then you could get this 290. It has the best cooler of the three listed but also has the lowest clocks. However getting it to up to speed will be very easy.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-348-SP&groupid=701&catid=56&subcat=1752
Is it just a case of raising the sliders for Clock speed & VRAM in MSI Afterburner/CCC to increase performance?
Also, I read somewhere that the 780 has better minimum FPS than the 290, can anyone confirm if this is rubbish or?
