Thanks guys appreciate comments. Have have the g930s but had so much greif with the software and them cutting in and out.
Yeah i regret buying them now for the exact same reason, however i have got them to stop the on sided thing after about a week of attempts. the only other issue i have with them is when the battery gets really low and you put the charger in and the headphones then turn off. you have to sit and fiddle with them for a couple of minutes to get them to charge and stay on.
since i reinstalled windows on a new SSD i just cant get them to load, tried ALL the work around but nothing seems to get windows to see them correctly... they work fine but i can't get the Logitech software to see them and all the extra stuff
Logitech forums are full off it, shame
Yeah so how it works for me is when the PC boots with or without the headset on / off / USB connected or WiFi Logitech will not see it. No matter what port or driver version.
If I then close the software and right click and run as admin it will turn the headset on and off and then connect and work.
However I have uac off and have tried a scheduled task but that won't do it.
Head wrecking and annoying.
have you tried a different usb port (i assume you have) when i plugged mine in first time, what ever usb port they were in, i think it was usb 3. Once the headset was turned out it would just keep connecting and disconnecting over and over due to the usb port, changed port and it worked fine. If they would just fix the software the headset would be perfect, but alas they haven't and probably wont
I have the Creative Sound Blaster Tactic3d Wrath wireless gaming headset and think they are amazing. The sound is crisp, clear with loads of features for creating a custom sound profile.
