With respect, you have an FX-83##, i also have an AMD CPU, they are not very powerful, certainly not as powerful as a more expensive Intel CPU, you would benefit from an AMD GPU and Mantle if you play BF4, in MP your minimum Frame rates will be massively higher in AMD's Mantle API than DirectX, i'm talking the difference between 50 FPS to more than 100 FPS.
Trust me, i know![]()
Thing is, if you can deal with the stock cooler the R290 is a steal at £200 second hand. That'll allow you to run most games maxed or near to it at that resolution.
If not, then I'd look at either a GTX770 or an R280X depending on the deals you can get on each and if you want things like PhysX/3D.
That, for me, is where my £200 would go.![]()
would it really be that much
Click on the review in my signature, If you play at maximum settings it will not be 100%+ as in such case your bound more by the GPU. not the CPU so much, but still very significant, there is an example of the difference at maximum settings in that review.
At lower settings (CPU bound) its huge. i have some screenshots, let me find them and i will post them.
you can tell with the pics also what game is that ?,
Come on, keep up with it. It's BF4.
