- 26 Apr 2004
- Milton Keynes
Hi Guys,
Looking for recommendations here because the range is a bit mind boggling.
I've done a bit of parts scrounging, and filled the gaps, and managed to put together a relatively nice HTPC. The trick is that the old Antec Sonata II case it's in is just a little bit too big for the room it's in.
(42.5cm H x 46.3D x 20.6W)
Ideally, I'd like a case that'll take an M-ATX motherboard, an ATX PSU and ideally, the Gelid Tranquillo cooler (which I believe is 153mm high), and be as small (with ok airflow) as possible.The Gelid is the awkward part, but ideally I'd like to keep it to a) keep down costs b) the machine is running an unlocked Phenom II quad so would need a reasonable cooler to stay cool at low RPM.
Given our room aesthetics, white would also be a bonus.
The machine doesn't need much in the way of 5.25"/3.5" drive bays, as I'm running the OS off a USB stick, and it will only have a maximum of one DVD drive. Additionally the machine only uses one PCI-E card for graphics/HDMI capability.
